0 rate add a leafs
Discussion in 'OffRoad Design' started by big83chevy4x4, Jan 6, 2003.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    can you double them up. i was thining about the 4" shackle flip with 2" bolcks, but now im thinking a 1 in add a leaf and an a-tron shim. is this posible? would it be safe? it would also be just for the rear. i have a long bed truck.
  2. GRINCH
    GRINCH 1/2 ton status
    Jan 30, 2001
    1,951
    Helena, MT
    I have the shackle flip, add a leafs, and a tapered zero rate on my 90 Blazer. I towed a tandem axle trailer tipping the scales at over 7k from Ga to Montana with no problems. It was a little bouncy at times but nothing major. /forums/images/graemlins/thumb.gif
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    It's probably fine, but I'd look at tack welding them together to eliminate one surface and you might consider a plain 2" block with the taper on it. This isn't a lot different from adding several extra leaves to the pack but it does start getting tall.
