02 avalanche lift
Discussion in 'The Garage' started by noho blazen, Nov 19, 2006.
  1. noho blazen
    noho blazen Registered Member
    Oct 7, 2006
    19
    mass
    how many inch of lift i would need to clear 35-14.5 boggers
  2. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    how much pavement use? how much offroad use? if its just pavement use, you can run a 3" BL with some insanely backspaced wheels
    if it were me, since it costs nearly the same to have a functional vehicle with a solid axle swap, i would do one that netted about 6" of lift and lift the rear with a shackle flip and a zero rate, maybe a 2" BL...
    8 inches... would clear them fine...
  3. Cornfield creations
    Cornfield creations 1/2 ton status
    Oct 19, 2005
    1,283
    Jasper, Indiana
    Well considering the avalanche has a 5 link setup in the rear with coils shackle flips and so on would not work, unless its a 2500 version. I believe they have leaf springs. With the body cladding as all '02's did, a 6" lift you will barely fit 35x12.50 Here is a website that is all about avalanches. I was a member back when I had my '04 Z-71.
    www.chevyavalanchefanclub.com
    They have forums on there with people that do just about anything to them.
    THey also have a offroading club called "Lifted Nation" The nation above the rest. They are pretty informative on there. Here is the link for the offroad forum. http://www.chevyavalanchefanclub.com/cafcna/index.php/board,188.0.html
    Enjoy!
