04 2500HD what t-case fluid?
Discussion in 'The Garage' started by sled_dog, Jan 23, 2007.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Mitchel On-Demand says Auto-Trak II fluid for the NV case, in the 2500HDs. But the truck is a manual shift case, not a push button... We just switched from AllData to Mitchel(I want to kill management) and I am not sure I trust it. Can anyone tell me which it should have? I will have the truck up in the air in a few minutes to confirm what Tcase is in it.
  2. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,065
    Colorado
    :dunno: I thought they were all ATF?
  3. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    a lot of newer ones take Auto-Trak II fluid. I don't think it has to be an auto-trak case to require it.
    Mitchell On-Demand SUCKS! It doesn't list the case this truck has. It has a NV 261. It only lists a 262. I am just puting ATF in the damn thing.
  4. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    You will be fine with the ATF. The auto-trac fluid has limited slip stuff in it very much like what you would add to a clutch type limited slip differential. Wouldn't hurt to put it in it either. Just a hell of a lot cheaper to put atf in it vs. the autotrac fluid.
  5. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    You like NO DATA?
  6. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    My 2002 says ATF Dextron III on the case itself.
  7. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    did you check the owners manual?
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I LOVE All-Data. I use it more than I do the Mitsubishi Service Computer. Have you ever used Mitchell? I think its horse**** in comparison to All-Data, and the Labor times are lower :mad:
  9. darryl
    darryl Registered Member
    Jan 14, 2007
    33
    edmonton canada
    mitchell has better transmission wiring diagrams but alldata is easier to use
  10. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    in my experience wiring diagrams in All Data are straight out of the factory service manuals. I know they are when it comes to Mitsus and Fords.
  11. Cornfield creations
    Cornfield creations 1/2 ton status
    Oct 19, 2005
    1,283
    Jasper, Indiana
    Auto trac is used on transfers with the auto 4WD option. Auto trac is blue in color. Check your fluid, if its red, then its dex III, if it's blue (which I believe only 1/2 tons had auto 4WD) then its auto trac
  12. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    Dexron 3 or better, just shy of 2 quarts. (1.8)
