06 wheels..
Discussion in 'The Garage' started by Confedneck79K30, Oct 22, 2006.
  1. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    so guys and gals, will the wheels from an 06 duramax 2500 fit my 79 one ton running gear?same lug pattern??
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    They might fit, but will have alot of offset, and might look goofy.
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    they're 16 x 6.5, with some crazy backspacing. they dont look quite right on an older truck.
  4. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    ahh, did i mention i have a dually? would that help any? my neighbor has a set with like 200 miles on them...
  5. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    It might work with your dually. Best way to find out, is to talk the nieghbor into letting you try em on.
  6. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    supersize75 is running that style of wheel - i think it looks pretty good -
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    just in case that got missed... :whistle:
  8. IGOR
    May 16, 2000
    2,303
    19
    Damascus, OR
    I did see that - but he said the neighbor's 06 was a 2500 - the 06 dually's are all 3500s (or above) - so yes the 06 wheels will bolt on - no you cannot use them in a dual wheel application though without some funky spacer sh!t between the wheels.
  9. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Yeah, I saw it too. I sort of thought he ment that he had the hubs that could handle the back spacing.. but who knows. I figure if the H1's can be ran with the dually D60F, then these should be ok too, it that is what he has.
    Sounds like we need more info! :D
  10. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    yes i have a dually and his 2500 is indeed a SRW... and theyre the exact wheels superdestroyrebuildsize75 has..
