1" 0 rates
Discussion in 'The Garage' started by mightywhitey_k5, Feb 3, 2005.
  1. mightywhitey_k5
    mightywhitey_k5 Registered Member
    Sep 3, 2004
    74
    what are the advantages if any of zero rates and why are they generly used.
  2. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    a zero rate gives you another inch of lift with out changing your spring rate.
    Some of them also alow you to move the axel for ward, and they bolt to the leaf pack...making it different from a block.
    if you want the hassle you can take an overload and just cut it and make your own...but that is no fun.
  3. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    They are good for the common saggy rear end in most K5's. The 1" zero rate usually puts it back in line with the front.
  4. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    [font=Arial, Helvetica, sans-serif]allow you to move the axle 1" or 1.5" forward or backward from the spring pin location. You can also leave the axle right on the spring center pin if you like and only use t[/font][font=Arial, Helvetica, sans-serif]hem t[/font][font=Arial, Helvetica, sans-serif]o raise the truck 1". [/font]
  5. la_blazer82
    la_blazer82 1/2 ton status
    Apr 12, 2004
    148
    SoCal
    The zero rates I have for the rear have three locations (assuming to move forward, center, or backwards). Would this solve some vibration problems from lifting, instead of having to use a shim. If so, would the front hole be used to move the pinion forward?
  6. mightywhitey_k5
    Sep 3, 2004
    74
    cool thankx for the info.
  7. AkMudr
    Dec 30, 2004
    917
    Alaska
    I dont think the zero rate will hep with vibration due to driveshaft angle. The only way to fix that is to basicly increase the pinoin angle. The zero rate will do 1 of 3 things
    1 Lift the rear 1" by using the center pin location.
    2 Be used to move the axle 1" forward/backward and lift 1"
    3 Move the axle 1.5" forward/backward and lift 1"
    Notice the 3 pin locations. You kinda hafta get it installed to really figure it out...looking at it will kinda make you go "huh" Thats how I was at first til I saw it installed.
  8. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    I believe that you can also get the 0 rates with an angle machined in to it to help with pinion angle.
  9. AkMudr
    Dec 30, 2004
    917
    Alaska
    Yes you can, I'm lookin or someone who does that. :D
  10. jkce457
    jkce457 1/2 ton status
    Nov 22, 2002
    135
    Southbury, CT
    You get get them direct from ORD machined on an angle.
