1/2, 3/4, 1 tons?
Discussion in 'The Garage' started by stizkidz, Apr 3, 2005.
  1. stizkidz
    stizkidz 1/2 ton status
    Nov 11, 2004
    219
    near Atlantic City, NJ
    Trucks have been coming in these three designations for years: 1/2 tons, 3/4 ton, and 1 ton. What is the purpose of buying a new truck in any of these 3 specs? Why would you want a 1 ton vs a 1/2 ton truck? I just don't understand why people shell out $60k for a brand new F350 when it seems like there isn't much you can do with an F350 that you couldn;t do with an F150. I understand that the F350 is obviously bigger, stronger, and more powerful but I ecspecially do not see much of a difference between the F250 and F350.
  2. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    higher load and towing capacity is the biggest factors. you cant tow a big 5th wheel or travel trailer with a 1/2 ton.
    you can tow a meduim sized load or trailer with a 3/4 ton, but you cant tow/haul the same load a 1 ton could.
  3. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    Braking systems, hp/and tq, larger beefier frames, higher capacity springs, and the one tons also offer a dual rear wheel option the 150 would never see.
    None of the big three offer a Big Block or diesel in the 1/2 tons, or the uber beefy transmissions. The 1/2 tons are glorified cars with box's IMO. You need a pick-up to 'work' and it's either a 3/4 or one ton.
    Rene
  4. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Its the rating of the amount of load they can carry safely....
    If you pull heavy loads, get a one ton.
  5. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    If you're buying a truck just to have a truck get a 1/2 ton. No shame in it and you can still haul the sheet of plywood or other misc stuff that won't go in a car. If you are buying a truck for serious work then you know if you need a 3/4 or 1 ton.If you're doing construction using a toolbox bed hauling a bunch of stuff a 3/4 ton will server you well. If you are consistantly towing over say 8k lbs, hauling over a ton, or need udal rear wheels (more payload capacity) get a 1 ton.
    We use a 3/4 ton 4x4 for general utility around the cemetery , bad traction dumping (it has a wood dump bed) and plowing. We have a 1 ton 4x2 dually with a 10.5' dump bed for hauling dirt, quarry dust, gravel, etc. And we have another 1 ton 4x2 dually with a flatbed, liftgate, and crane for hauling and setting the headstones.
    Each truck has it's purpose. Our flatbed isn't a 4x4 because we don't need to pay the extra expense for 4wd because that truck doesn't get used in winter. The 3/4 ton utility truck allowed us to just get a 4x2 dump truck saving some money and with a traction device and chains it will do what I need. And when it doesn't I use the 3/4 ton.
    Sure I would love all my trucks to be 1 ton 4x4 dually turbo diesels. But unless you have a lot of disposable income just buy what you need.
  6. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    If you have a family, you probably want 4 doors. If you have a camper, it likely fits best in an 8' box. That takes you into 1-ton turf right there ;)
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    you answered your own question.
