1/2 and 3/4 d44s, same yet different
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by misfit, Nov 30, 2000.
  1. misfit
    misfit 1/2 ton status
    Jul 21, 2000
    324
    south central wa state
    ok, most will agree that youll have to grind the calipers on a 3/4 d44 if you run 15" wheels. but ive been told by more than one person that the 1/2 and 3/4 d44s are identical in strength, etc. does one have larger calipers? why is grinding necessary?
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    The 3/4 tons have larger rotors, but I believe they may use the aame calipers. but with the larger rotors and backing plates it put the caliper up higher and therefore you need to grind.
    HTH
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  3. i_4x4
    i_4x4 1/2 ton status
    Feb 20, 2000
    359
    Brighton, Colorado. USA
    When I did my conversion in mid July on my '85, I had a corp 10 bolt, and replaced it w/ a d44 3/4 & 14ff. I decided to try using my original calipers, because I was being lazy to have to bleed them. I found out they are they same size, & so are the brake pads. I'm still using the 10 bolt set up, seems to work just fine. Hope this helps.
    Later, Ed i_4x4
    LET'S ROCK
    Don't follow me you will get STUCK!!
  4. i_4x4
    Feb 20, 2000
    359
    I just remembered the other reason for not switching calipers, was the banjo bolts are larger on 3/4 set. Haven't changed my brake hoses yet.
    Later, Ed
    LET'S ROCK
  5. Grim-Reaper
    7,385
    Atlanta
    Yes you can do it and retain stock claipers but there are some differences. towrds the end of the D44 run they did use a D44 with a thinner wall tube on the 1/2 tons. I think the 10 bolts are the same. Thicker if it's a 3/4 ton. The knuckle is the same so yest that hub parts are interchangable. Now my 75 has a half ton D44 but it thick wall. It is much thicker than the tube walls on my 79 10bolt. Another thing to watchout for is till around early 74 the D44 3/4 ton had external hubs. You don't want those. the hubs are hard to find.
    Diging it in the dirt with my K5's
    Grim-Reaper
    http://grimsk5s.coloradok5.com/
