1/2 or 3/4 dana 44?
Discussion in 'The Garage' started by K1Orion, Jan 23, 2003.
  1. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    Is there a difference between a 1/2 ton and 3/4 ton dana 44 other than from the knuckles out?
    What i'm getting at, is i need new axles and i thought about ordering some from warn. But i was told that the ones for a 3/4 ton are longer and that warn only makes them for a 1/2 ton.
    So what is the difference?
  2. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    Shafts are the same.
  3. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    exactly the same from theknuckle out. /forums/images/graemlins/thumb.gifincluding the shafts.
  4. K1Orion
    Jan 8, 2003
    812
    st.louis,MO
    Maybe i didn't ask the right question. Are the inner xle the same between 1/2 and 3/4?
  5. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,601
    551
    Wasilla AK,
    There the same also /forums/images/graemlins/cool.gif /forums/images/graemlins/truck.gif
  6. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    Shafts diff in corporate from 44.1/2--3/4 same on each.
  7. chulisohombre
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    the only way the shafts differ ive heard is that the pre 73 dana 44 shafts are easier to break because they changed the design in 73 to not neck down near the knuckle as far as pre 73.all dana 44 shafts will interchange though.just not 10 bolt corp axle shafts.they are different length form the 44
  8. K1Orion
    Jan 8, 2003
    812
    st.louis,MO
    Thanks everybody.
    Anybody used Warn's axleshafts? They say they are garuanteed for life except yokes damaged by u joint failure.
