1/2 to 3/4 master cylinder
Discussion in 'The Garage' started by mjnemmer, Oct 25, 2006.
  1. mjnemmer
    mjnemmer Registered Member
    Oct 17, 2006
    12
    sonora,CA
    i went from 10 bolts to a dana 44 and a 14 bolt and the brakes bearly work. i blead the brakes and the pedal still gose to the floor any ideas?
  2. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    you easily could have damages your master cylander hile bleeding the brakes.
    i run the stock master cylander, but i run a prop valve from www.inlinetube.com
    call them, and they will tell you exactly which one to use.
    i have no problems at all
  3. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    Don't see where a proportioning valve would let the pedal go to the floor. you either have alot of air in it still, and need to bleed more, or the rear brakes are way out of adjustment, or maybe even front calipers not sliding. put yourself a rubber hose on the bleed screw, with the other end down inside an old bottle with a little brake fluid in the bottom. open the bleeder and pump away. this will let out the air, without sucking any back in.
  4. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    for about 20 bucks, you can make a power bleader that will flush your whole system in 30 seconds.
    buy a power sprayer, the kind you pump up to spray weed killer or decks or what ever, ditch the sprayer and fit the hose to a barbed fitting, and tap that in to a plate large enuff to cover the front half of the MC.
    clamp that on to the MC with a piece of rubber gaskit (plumbing suply cheap) with a little brake fluid in the sprayer, pump it up then crack you bleaders, it will flow continusly untill you close the bleaders., repeat for the back half.
    NOTE: if you DID blead proberly and the pedel is way to soft, pull the MC with the lines atached to see if there is fluid comeing out the back of it this would indecate worn seals from excesive cylinder travel, need to replace the seals with a re build kit, or make it easy and buy a new cly
  5. goldwing2000
    goldwing2000 Guest
    Providing you're still running drum brakes on the rear, I vote for rear shoes not adjusted properly.
    If you converted to rear disc... then your problems are just beginning. :D
  6. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    I'm having the same problem after switching to one tons, but I put on a new one ton M/C and gravity bled a full large bottle of brake fluid through it.
    It is still spongy and soft.
    Could the prop valve be bad?
    It has a button on the front that moves when I push the brakes.
  7. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    Your title makes it sound like you have alread swapped out to the 3/4 ton master cylinder but your post didn't mention it....have you?
    -Avery
  8. mjnemmer
    Oct 17, 2006
    12
    sonora,CA
    its an 87 carborated blazer with the factory master and iv blead two one liter bottles of fluid through it and im still going to the floor with the pedal. i adjusted the rear drums but that only helped it didnt fix it.
  9. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Do a search. There are several recent threads on this problem. An older thread I made has all the info you need.
