1/2 ton 3/4 ton lift springs
Discussion in '1936-Present Suburban' started by darkshadow, Dec 7, 2005.
  1. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    are there really a differance? are the spring rate different enuff to change the amount of weight i can carry/tow? i see cheap springs from blazer and half tons... or should i just just this up front and flip the rear keeping the stock heavy springs?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I don't know about the lift springs, I would believe they are different. But I do know that with the stock springs, all the ones I've seen, 1/2tons only had 2 leafs and 3/4tons had 3 leafs :dunno:
  3. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    is this for the front or rear springs?
    I have 5 leaf 1/2 56 now but friday I am swaping them for 8 leaf 3/4. I can post some side by side pics and let you know of driving impresions too
  4. Geargrinder
    Geargrinder 1/2 ton status
    Jan 21, 2005
    258
    Medford Oregon
    If we are talking rears, there IS a diferance. 3/4T=56" 1/2T=52". If we are talking fronts I have not seen a diferance between any of 'em, stock or lift.
  5. dleroy43
    Jul 22, 2002
    1,517
    Martinsburg WV
    my 1/2 ton has 56"s stock
  6. dleroy43
    Jul 22, 2002
    1,517
    Martinsburg WV
    heres the 1/2T with an AAL and 3/4T 56" springs
    The 3/4 has more arch than 1/2T with a AAL
    I got 1/2" taller and they are softer (jumping up and down on the bumper is not a real test but it works) :D
    I also discovered today that I ground my 6 month old rear u-joint bearings into a fine powder :doah:
  7. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    thanks dleroy, so i really should look to 3/4 ton springd then.
    and we established that 1/2, 3/4 tons fronts lift springs are the same right?
  8. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    well 1/2 ton fronts came in 2 leaf only.
    The 3/4 tons came in 2 or 3 leaf, not sure what the break was but it had to do with GVWR ratings.
    The rears were also depending on the weight ratings and were always more on 3/4tons since most of your payload goes in the back.
    The fronts were upgraded when you had upgrades on the front like brush gards or heavy duty bumpers and roof rack where you could end up with more weight than the engine, also the 454 equiped burbs came with 3 leaf springs.
    I believe also the burbs with a tow package go them because when you use an equalizing hitch you end up with more weight on the front.
    :D
