1/2 ton, 3/4ton, 1ton question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Bigmeats, Mar 5, 2002.
  1. Bigmeats
    Bigmeats 1/2 ton status
    Jul 29, 2000
    523
    Manhattan IL
    What do these really mean? Is this a rating that the truck can hold, I know the difference between the three, i am just woundering what determines the rating. This post is the result of working midnights and being sleep deprived /forums/images/icons/smile.gif Amazing what a tired brain thinks about.
  2. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Most talk here about different tonnage refers to axles. A 1/2 ton is usually a ten bolt or twelve bolt rear w/ a ten bolt or D44 front axle and six lugs. A 3/4 ton is a 14 bolt rear and a D44 front w/ 8 lugs, and 1 ton is a 14 bolt rear and a D60 front w/ 8 lugs. The ton designation is out of what size four wheel drive came from the factory w/ what axles. I think that's pretty accurate. Hope thats clear enough.
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    It doesn't really mean anything. I think those designations originated from old military terminology. If you want to know what kind of work a truck was built to do, look at the GVWR, and the front and rear axle ratings.
  4. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    79-87 3/4 ton's got an 8 lug 10 bolt front end and some of the got semi-float 14 bolts.
  5. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    i have an 8-lug 10b front and a 8-lug 14b sf rear, i'm a 3/4 ton.
  6. dysphemism
    dysphemism 1/2 ton status
    Oct 26, 2001
    667
    Fremont, CA
    The tonnage of a truck is how strong it is in general. This means frames, springs, master cylinders, and axles. 1 ton trucks ride higher due to their bigger frame, and have bigger axles and master cylinders. A lot of it is the axles but its not all that is involved.
