1/2 ton and 3/4 ton burb whats the diff?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sandracer0004, Jan 22, 2004.
  1. sandracer0004
    sandracer0004 1/2 ton status
    Jun 24, 2003
    108
    San Jose, CA
    guys i have been in big debate about selling my burb and getting a 3/4 ton 454/400 burb, for towing. currently i have a 350/700r4 burb, with d44/14bff. what are the major differences that distinguse a burb as a 3/4?
    frame
    brakes
    master cylinder,
    proportioning valve?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    The axles are the only difference....althought a 3/4ton 4x4 never came with a factory 454.
  3. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    The axles are the only difference....althought a 1/2ton 4x4 never came with a factory 454.
    [/ QUOTE ] fixed it. /forums/images/graemlins/thumb.gif
  4. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I think the proportioning valve is different to compensate for the bigger brakes. I have probs with my big 2.5" rear drums wanting to lock before the front disks on my K5.
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Notice Muddytazz said "3/4ton 4x4"? He is right. And no 4x4 Sub ever came from the factory with a 454. Only the 3/4 ton 2wd's came with them. /forums/images/graemlins/wink.gif
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    You're forgetting the springs.
    Yeah the difference between the 1/2 and 3/4 ton is the 8 lug axles and the springs.
    It's a shame no 4x4 burb came with the 454, you'd think since it was an option on 2wd it would be on 4wd too where you really need it. /forums/images/graemlins/grin.gif
    Anyway I'm getting mine with a TD6.2l
    Picking it up this week end.
    /forums/images/graemlins/pimp1.gif /forums/images/graemlins/pimp1.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/burb.gif
  7. sandracer0004
    Jun 24, 2003
    108
    San Jose, CA
    ya i noticed that since i swaped axles my brake light is always on, which is wired to the proportiong valve, i should prob replace it huh?
    also do you guys get a adjustable valve to adjust the rear brakes for disks?
    for lest presure?
  8. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Well, just to clarify, '92 - later (the "new" bodystyle) 3/4 ton 4x4 'burbs were available with the 454. But then of course you're not getting a TH400, you're getting it's electronic counterpart - the 4L80E.
    In the generation of suburban I believe you're talking about ('81-91), the only way you could get a 454 was in a 2wd 3/4 ton.
  9. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Thats friggin' dumb. Hmm well I learned my daily 1 thing today. /forums/images/graemlins/thumb.gif
  10. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    I agree /forums/images/graemlins/frown.gif
  11. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    um, don\'t forget the frame is different too!!!!
    well, you asked about MAJOR differences, and not sure where you'd classify the FRAME.. but... (as yours is an 89..mine a 91), here's what the 91 spec sheet has on a few things.. /forums/images/graemlins/deal.gif
    16" wheels on SOME 3/4 tons...
    Frame thickness: 1.77 vs 1.92 in
    section radius: 3.57 vs 3.88 cu in
    RBM/Frame: 139,230 vs 151,320 in/lbs (NFI /forums/images/graemlins/ignore.gif what RBM means)
    Those axles also change rear-brakes from 11.15 x 2.75 to a 13.x 2.5 (or 107.42 facing contact vs 116.73 rear) ..
    Front rotors are 11.86 x 1.29 vs 12.50 x 1.29 with 37.63 facing and 42.98 on 3/4s....
    I think those frame & brake differences account for some of the INCREASED tow ratings and such.. /forums/images/graemlins/thumb.gif
  12. dremu
    Feb 27, 2000
    15,967
    459
    East of San Francisco
    Re: um, don\'t forget the frame is different too!!!!
    My '90 3/4 ton had 16" wheels stock. (Then my wife took it... well, it still has the 16" wheels, but I don't have it /forums/images/graemlins/frown.gif )
  13. Grim-Reaper
    7,385
    Atlanta
    I have been trying to come up with a reason for this. As far as I can tell this is a late 60's early 70's deal. I think they found the small u-joint D44 and nepco front axles couldnt' handle the torque and were blowing out. Even though they made the D44 a little stronger in 74 with the 297 joints it was never changed. I think in 76 when the D60 became availbel in the 1 tons that you could get the 454 in a 4x4 but the D60 was never available in the burb so never got it till 93-94 (No 454 burb for 1 or 2 years with the body change I have read somewhere)
  14. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    I kinda suspected that but couldn't confirm.
    I know that on the 1ton trucks I can see the difference in the frame thickness but never compared the burb frames.
    Thanks for the acurate info.
  15. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    my 89 3/4 ton has, 16" wheels, 14 bolt semi floater, and 56" 3/4 ton rear springs.
  16. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    RBM is an abvereation
    R=Rockwell ( a type of metal hardening
    B= (Brinell) a industry standard for measuring the Hardness of a metal aka The Leval - Grade of the Harding ( kinda like a Grade 5 or a Grade 8 Bolt
    M= you guessed it metal
    So there fore the stats show that a 3/4 ton frame is hardened
    151,320 in/lbs -139,230 = 12,090 in/ lbs stronger
    I new that class in Metalergy would pay off some day
    Guess i should have went to spelling class instead
    The Doc
  17. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    for lest presure?
    its not pressure as much as it is volume, for the most part.
    pressure is always before a restriction and you want the restriction to all be the calipers and not a kink or something in the line, etc.
