1/2 ton and 3/4 ton chassis
Discussion in '1936-Present Suburban' started by 84CUCV, Dec 15, 2004.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    I have a 90 1/2 ton 4x4 and i found a 85 3/4 ton. I would like to start with one of them as a winter project. Is there a big differnce in the frame? I have a good 350 and 60 and a 14b just sitting wating for the sub. Let me know what you guys think
    Thanks mike
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    To the best of my knowledge, the frames are exactly the same.
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    My knowledge is that the frame on the 3/4 ton is thicker, I don't know if it's enough to matter but I believe if I had both and both were in decent shape I would use the 3/4ton.
    If the 1/2 ton was in better shape then I would use it.
  4. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Thanks i thought they 3/4 tons had a better frame. mike
  5. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK thanks imiceman44
  6. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    i've got a spec book on the 91's and it indicates a thickness & strength difference between 'em. I think all the length/wideth/exterior measurements are the same (swappable)... but the 3/4 is more beefy!
  7. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Thanks woddy9. mike
  8. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Yes everything is swappable between the 2 with no problems. I have a frame specs in my 75 factory manual and in my dads 81 factory manual. I noticed that over the years things changed cause my 75 1/2ton frame is the exact same thickness as my dads 81 3/4ton frame :dunno:
  9. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Yes as the years go by, they go thinner on the frames and get closer to the limits.
    They used to make things beefy now they make them work.
