1/2 ton axles and jumping
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DesertDueler, Jan 1, 2003.
  1. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Both me and my buddies went jumping in our trucks for New Years. His is a 78 K5 with 6" lift on 35" boggers. 12 bolt rear, dana 44 front. Mine is my burb, 4" lift on 38.5" Sxs, 12 bolt rear 10 bolt front. Anyways He broke 5 of 6 lug nuts and studs off the right rear tire. So my question is, does anyone know of some longer and stronger studs. We both run aluminum wheels, so there isnt alot of threads holding the lug nut on like on a steel wheel. BTW my 1/2 axles did just fine prerunnering through the desert at 65 mph. I even went through some dirt bike whoops.
    Thanks Dan /forums/images/graemlins/burb.gif
  2. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    Summit racing has longer and stronger studs
    kinda like the ones used on race cars.
    Bo /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  3. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Ive used them on my racecar, but wasnt sure if there are the same for our trucks.
  4. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Truss the darn things before you break the axles themselves!!!! BTW, got pics?? /forums/images/graemlins/thumb.gif
  5. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    There were a few people video taping. We were drag racing through the desert. We are going out again in a couple of weeks, and will take some pics. I miss my sandrail (broke the frame in Glamis clearing 15 feet of air for the 3 time in a row /forums/images/graemlins/grin.gif). So my Burb is getting to do some jumping.
  6. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Make sure you have bumpstops that work too. My avatar jump broke both of my rear shocks. /forums/images/graemlins/eek.gif
  7. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    like buba said truss them or you will regret it /forums/images/graemlins/frown.gif
  8. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Trussing them is a good idea. I am going to shortly. I was worried about wheels falling off like my buddies first though.
  9. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    if you swing out through yuma let me know man.
    yeah, and if you need parts cus you break somethig out there let me know as well.
    i might be able to help.
    Grant
  10. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Maybe you should of $$$$$$ into some shocks before you did that. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  11. zcarczar
    Feb 10, 2002
    2,495
    My shocks are/were pieces of crap anyways. I think they are worn out, when or if they break again im going to try and get some 7100's.
  12. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Try searching in the ord forum from a long while back. I think watson posted some part #'s for 1/2" studs. I had one of my 7/16" studs come off in my hand while I was dooing the brakes. I changed the front to new studs (same diameter) but should have done the rear too because I lost my rear wheel on the hwy doing about 80mph.
    Also you will want to put bigger spindle bolts on to keep the spindle on the truck.
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Convert to 3/4 tons and you'll get 8 9/16" studs on every wheel.
  14. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    3/4 ton makes the truck weigh more. I probably couldnt even get that 14 FF off the ground /forums/images/graemlins/grin.gif.
  15. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    you can get anything airborne with the right ramp and speed! we used to get my 76 in the air all the time, 3/4 ton front and 14 bolt rear! at the time it only had a 305 in it!! But it was the landing that killed it. bent frame/broken body mounts! oh,,, TRUSS TRUSS TRUSS!!
  16. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Keep jumping your 'burb and you will end up with a badly broken truck. /forums/images/graemlins/shocked.gif They weren't made to fly... /forums/images/graemlins/wink.gif Even with trusses, one bad landing will snap the front axle and the truss. /forums/images/graemlins/frown.gif
  17. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Traiged got to you before I did, yes you can upgrade to 1/2" studs and you will never break them. I had that on my 73. You have to drill out the holes to bigger in the hub and discs.
    As for jumping like everyone said truss them and I would also weld the tubes to the pumpkin, those rosettes tend to break loose and you turn a tube and destroy the pinion and gears.
  18. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Use a 14 SF, not that much heavier and still 8 lug. Thicker shafts too.
    The front axle is already full floating obviously. Simply weld the tubes to the pumpkin.
  19. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    as a desert guy you already know the key to jumpoing is long travel suspension complete with real shock absorbers.
    trussing or ?? will not be enough to save any dif from the the truck coming down solid on it.
    just a matter of time
