1/2 ton brakes and 35s
Discussion in 'The Garage' started by YELL78, Dec 19, 2005.
  1. YELL78
    YELL78 Registered Member
    Feb 27, 2005
    54
    ALBUQUERQUE
    can you guys tell me from your experiance if my 1/2 ton stock breaks are adiquate for 35s?
    i just bought some crager soft eight 15X8 steel wheels and i just lifted my 78 swb and now i cant decide on 33s or 35s, i know i wont have a problem with breaking with the 33s but im not sure about 35s can yall help.
    also what about acceleration with 3.73s and a th350.
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Mine was fine with 35's. well....as fine as it can be with these antiquated brakes!!
  3. neubanksc5
    neubanksc5 1/2 ton status
    May 13, 2005
    281
    Concord,CA
    i have 33's on my blazers stock half ton axles, brakes work fine, well they did but I think my master cylinder is taking a dump. but I know plenty of people running 35s on 1/2 tons, brakes work fine.
  4. mrk5
    Apr 20, 2004
    12,335
    1,045
    Northern Colorado
    I'm running 37's on a 1/2ton brakes, and the seem good to me. Tested them out good on Hell's Revenge @ Blazer Bash this year. Plus the drive there over the mountains.
    I will note that I have hydroboost breaks, and I have been sure to keep the rear drums maintained. I think the rear brakes often go neglected.
    3.73 with 35s would be okay, but personally I would prefer 4.10s
  5. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Mine will lock up the 36's. They are 3/4 ton brakes, but as far as I know, the rotor got bigger than a 1/2 ton, but the brake pad is still the same size...so pretty much the same braking.
  6. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    1/2 ton brakes
    1/2 t, 10Bs, 31", Stainless braided brake hoses, drilled rotors and drums, stops hard and without fade; freaks-out the punks in tuner cars.
  7. 84blazin
    84blazin 1/2 ton status
    Nov 9, 2004
    345
    Queen Creek AZ
    I run 35s on 1/2 tons with 3.73 gearing... No problems
  8. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i could lock mine up real easy. never had a problem
