1/2 Ton Burby w/ 400 Trans driveshaft question
Discussion in 'The Garage' started by BigBurban350, Dec 24, 2003.
  1. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    I find through searching that upgrading to a 400 trans you need to adjust driveshaft lengths. Instead of getting my shafts adjusted, could I just find used ones for a 3/4 Suburban or 3/4 Longbox truck? I would assume they came stock with 400s.
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yep! alot of 81-up had the th400 in 3/4 tons especially with 14 bolt SF it seems, i see alot around here like that, they are the shorty 400 with bolted on output yoke, bolted to output shaft, they havhe a slip in them like a 4x4 rear shaft does because of the output style on tranny,
    what you needing to know ? anything else ?
  3. BigBurban350
    Jun 9, 2002
    711
    Michigan
    What I need to know is if I do find a used 400 possibly mated to a 205, if I can just purchase drive shafts for a 3/4 truck (burb or long box) and bolt everything on without having to get custom stuff made.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    well thats all gonna depend on total drivetrain length then,
    and also yoke style for front of case and well rear too.
    dunno
    good luck
