1/2 ton calipers same as 3/4 ton???
Discussion in 'The Garage' started by GM Man, Jul 17, 2005.
  1. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    Did a search, but didnt find what I was looking for. I have a 3/4 ton axle that I'm about to bolt up to my Jimmy and was wondering if the 1/2 ton calipers will work on the 3/4 ton axle?
  2. sweetk30
    Nov 1, 2004
    25,545
    540
    horseheads , ny 14845
    3/4 ton is same just a bit bigger piston. i used my 1/2 tons on my old 3/4 swap . o.k. for me.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    this is only part correct. the 3/4 with the 13" rear brakes had a bigger piston, the 3/4 ton with the 11" rear brakes have the same size pistons as the 1/2 ton.
    they bolt up the same
  4. Kingston
    Kingston Registered Member
    Aug 1, 2001
    7
    Alberta, Canada
    Yes they are. I just installed them on a 3/4 ton setup.
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    they will all bolt up, but if you have a bigger piston and then go to 1/2 ton calipers you are losing braking power with the smaller piston
