1/2 ton into 3/4 ton...how to do?
Discussion in 'The Garage' started by jdoe, Jan 28, 2004.
  1. jdoe
    jdoe Registered Member
    Jan 4, 2004
    6
    Currently, my dream truck is a 1/2 ton. I'd like it to be 3/4 ton. What would it take to make this happen? /forums/images/graemlins/k5.gif
  2. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Get yourself some 3/4 ton axles put them under
    You'll need
    Possibly new brake lines
    New Driveshaft U Joints
    New Rear Axle U Bolts
    Thats about it I think
    And the proper wheels and tires
    You could put a 14BFF in the rear and leave the front, but you'd need to match gear ratio and lug count
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Yeah pretty simple swap. A lot of people here run 3/4 and 1 Ton stuff. Find a wrecked 3/4 ton and get the axles u-bolts and spring plates. Get some new 8 lug wheels and a U-joint for the rear.
  4. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    depending on your purpose......& depth of your pockets... there's a number of other differences too.
    On my 91, it's frame (strength), axles & springs for starters. Tranny was different as well as brake systems. Most of these can be grafted across, but the most labor/wallet intensive one would be the frame swap-a-roo!
