1/2 ton to 3/4 swap chev k5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NeutralMan, Jan 2, 2002.
  1. NeutralMan
    NeutralMan Registered Member
    Jan 2, 2002
    15
    vancouver bc canada
    im doing a swap to 3/4 ton rear and front . i have a quick question on emergency brake cables. is it possible to cut the mount ( clip in mounts )out of the original backing plate and fit it to the 3/4 ton backing plate (bolt in place mounts)?
    or is there an easier way ?
  2. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Try doing a search on "emergency brake", this has been covered several times. Good luck!
    '85 K5 : Run it til it breaks, then fix it and go again!
  3. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Your basically gonna take the clip in mounts off the cables and apply those cables to the bolt on mount of the new axle. I did it and it has worked great for almost a year. A few others have done it too. If you need further help just ask.
    <font color=blue>It's easier to teach a child than to fix an adult.</font color=blue>
    <a target="_blank" href=http://community.webshots.com/user/geltyone>Webshots Pics.</a>
