1/2 ton truck with turbo 400
Discussion in 'The Garage' started by merace19, Dec 21, 2006.
  1. merace19
    merace19 1/2 ton status
    Sep 19, 2003
    372
    Mobile, Alabama
    Would a 88 1/2 ton truck have a turbo 400 in it stock? According to the 2nd pic down on that site i got a 400 in a 1/2 ton truck . http://www.700r4l60e.com/transmission_gm.html
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    No, its going to have a 700R4.
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    it is very possible that it came with a TH400.
  4. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    I believe a base model non-OD truck would have had a 400. By that year the 400 was the only 3 spd auto in production so that was the standard equipment auto. I'm not 100% sure this applies to the trucks but I know this was true of the vans, I got one of my HD case 400's from a base model Astro van. :D
  5. merace19
    Sep 19, 2003
    372
    Mobile, Alabama
    The pan on it and the side view look exactly like the 2nd pic down.Here is a pic of it. Its dark and raining now i could not get any more today.
  6. merace19
    Sep 19, 2003
    372
    Mobile, Alabama
    It has the thing with 4 bolts on it circled in red below.
  7. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,010
    7
    Binghamton NY
    GM also used a 375 or 475. There was a post on this awhile ago. IIRC it's essnetially a 400 with a 350 output shaft. Don't hold me to it tho.
  8. merace19
    Sep 19, 2003
    372
    Mobile, Alabama
    If it is a 400. It has a driver drop transfer case on it. I have a set of military 1.25 ton axles that i want to poke under it and need to replace the transfercase with one that has the correct drop and that will bolt to a 400. Is this a remove and replace with some thing like a 208 transfercase? The trans is brand new as well as the engine.
  9. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    passenger side drop 241 out of a 90-91 Burb or Blazer. if you get one that was originally behind a 700R4/4L60 you'll have to swap input shafts, as the 700 version is 27 spline, and the 400 version is 32 spline. you need the 90-91 version because it has the VSS on the back of the transfer case, rather than a cable driven speedo.
  10. sweetk30
    Nov 1, 2004
    25,554
    548
    horseheads , ny 14845
    i scraped a 85 or 86 c10. stock base base model non radio even. was 4.3 carbed v6 with hd case 400 2x4 all 100% stock from factory.
  11. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    my buddy has an 88 1/2 ton with a 400 in it from factory. I thought it was strange too.
  12. cabledawg
    cabledawg Secret Squirrel Premium Member
    Sep 12, 2006
    2,647
    Highway to Hell
    Certainly isn't a 700. The pan is the wrong shape. Assume it is a 400 and go from there. Sorry I cant help much with the Tcase though. I'm still learning myself.
  13. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I stand completely corrected.:doah: :laugh:
  14. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    If you are wanting a passenger side drop case a 208 or 241 should bolt in. You will need to know the spline count on the trans though. Generally Th400's are 32 spline but generally Th400's didn't come in 1/2 tons so you will probably want to check.
    If you have the electric speedo then you will want to find a 241 with an electric speedo to swap in to make life easier unless you don't care about a speedo.
    Harley
  15. merace19
    Sep 19, 2003
    372
    Mobile, Alabama
    Trail rig dont care about the speed o meter :) But i do want it to run right so if i need it i will get it to work. I did not want to crack it open to get the spline count on the trans. Did any 400's come with the smaller spline count shafts? I got my eyes peeled for a 208 or 241 but dont want to get the wrong one. Which is stronger? Better? I know the 208 is behind a lot of military trucks that are 1 ton.
  16. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    The 241 is marginally better then a 208. It has a true oil pump system were a 208 only has slingers, & it has the ability to be converted to fixed yoke output much easier then a 208. The 241 is basically an update slightly more evolved 208. The 241 also offers a slightly better lowrange of 2.72:1 as compared to 2.61:1. The downside is they are more rare & generally cost more money when you find them.
    That being said though, I run a 208 with good success as do many.
    Harley
