1/2 ton u-bolts to use with 1" zero rate
Discussion in 'Parts & Trucks Wanted' started by rogerwilco71, Jan 8, 2003.
  1. rogerwilco71
    rogerwilco71 1/2 ton status
    Sep 22, 2002
    179
    Central-Cal
    1/2 ton u-bolts to use with 1\" zero rate
    Have a flip-kit and 1" zero-rates and need some u-bolts. I think stock are too short and my current u-bolts accomodate 4" block and add-a-leaf. I'm an hour and a half (mountains) from the nearest place for custom u-bolts in Fresno. Just need that 1-2" over stock u-bolt or a source for the same application. /forums/images/graemlins/1zhelp.gif
    1986 K5 1/2 t
    -Matt
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Re: 1/2 ton u-bolts to use with 1\" zero rate
    <font color="green"> Measure how thick your spring pack is and let me know, I might have some that will fit. They were on with no blocks, but the springs were 6" superlifts with the overload, so they were a bit thicker than a stock spring. </font color>
  3. rogerwilco71
    Sep 22, 2002
    179
    Central-Cal
    Spring pack w/ 1" zero is about 3.5" and the axle is 3-3.5". From what I measured, it seems like an 8" u-bolt would work out (inner part of curve to top thread). Do you take gold doubloons, I feel paper money is so crass /forums/images/graemlins/grin.gif
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    please do not re-use u-bolts /forums/images/graemlins/frown.gif contact stephen at ord he will custom make them for you and ship them to your door /forums/images/graemlins/thumb.gif
