1/2 ton verses 3/4 ton 91 Suburaban
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tch777, Oct 10, 2005.
  1. tch777
    tch777 1/2 ton status
    Jan 15, 2003
    244
    Colorado Springs, CO
    So what are the differences in a 1/2 verses a 3/4 ton 1991 GMC Suburban?
    I know the rear axles are different 10B verses 12B and the rims on the 3/4 ton are 16 inch with 8 lugs.
    Is the frame the same?
    Are the braking systems the same?
    How are the brakes different?
    Basically I want my 1/2 ton to be a 3/4 ton. And I have too much in this 1/2 to sell it and start over.
    Also I searched but couldn't find the whole answer:
    If I find a 90 to 91 sub or truck with a 350 and a 4L80E what is needed to drop the tranny in and mount it to my 241 transfer case?
    Tim
  2. mini_mull
    mini_mull 1/2 ton status
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    Actually the 3/4ton has a 14BSF some are 6 lug, but most are 8 lug. While you're swapping anyways, you'd be better off using a 14BFF, since if you break an axle your wheel wont go flying down the road. You can also change your front to 8 lug pretty easily or just swap it too. There's a ton of writeups on the 8 lug conversion, if you can't find them let me know. The braking system is larger and more powerful. IIRC the MC is larger, and the rotors in front are larger, as well as the drums in the rear. I don't know about the frame, but I've heard people argue about it before. I think some years are different, but some are the same. For the motor tranny you'd need the computer that controls the 4L80e also, but I'm not sure if you'd need anything else.
  3. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    12 bolts are 1/2 ton rear axles.
    A 3/4 ton would have a 14BSF in the rear as was said. The 4L80E is a th400 so it should bolt up to a np241 that has 32 splines(your th700r4 does not, should be 27 splines)
    Brakes are physically bigger. That's why the 3/4 ton has 16" wheels, because the 15" wheels would not fit up front with out grinding the calipers.
  4. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    i think they nailed the 'biggie' differences.. (brake system & axle)...
    front roters (dia. x thick) 11.86 x 1.29 vs 12.50 x 1.29
    facing contact: 37.63 vs 42.98 (think this is also called 'swept area')
    rear drums (dia x width) 11.15 x 7.75 vs 13.0 x 2.5
    facing contact: 107.42 vs 116.73
    I think the 2500 also had a hydro brake option as well.
    but my 91 spec book also lists some frame differences. (I think it's partly in 'engineer speak). The side rail wideth & depth are the same, but thickness is .177 vs .192
    The section modulus (rails only, cu in) is 3.57 vs 3.88
    the RMI (NFI what that is) is 139,230 vs 151,320 lb/in
    I think part of that extra beef contributes to the larger numbers for tow-ratings. Towing also adds in the tranny & engine oil coolers. Krazy enough, it also advises the speed control & comfortilt steering wheel!
    I can give u the exact numbers for engine/axle combos if ya want..
  5. tch777
    Jan 15, 2003
    244
    Thanks for the information.
    That fills me in very well.
    Looks like I will just make this Sub a HEAVY half ton and be happy with that.
    Later
    Tim
  6. ccj8008
    ccj8008 1/2 ton status
    Apr 2, 2001
    228
    Polson MT
    I am pretty sure that the 4L80E didn't appear to 1991 and is worth skipping the 1990's for.
  7. woody9
    May 27, 2001
    602
    Howell, MI
    91 lists the RPOO codes MX0 for both 4L80-E & 700R4 and indicates the 4L80-E was only in R (2WD) models & 8600 GVWR.
  8. mini_mull
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    If you're saying the 4L80E was only in 2WD, that's incorrect, there's a '91 3/4ton 4WD in my driveway with a factory 4L80E, but maybe I just misunderstood your point. The '91 1/2ton version had a 4L60E (aka700R4). For '90 the 1/2ton had the 700R4, and the 3/4ton had the TH400 (basically a 4L80E minus the overdrive and electronic control). I agree, cc, the 4L80E is well worth skipping the '90 TH400's, I get crappy milage even with overdrive, and can't imagine what I'd be getting without it.
  9. tch777
    Jan 15, 2003
    244
    FYI
    My 1991 GMC suburban has a 700R4 not the 4L60E. I checked with the tranny id guides and mine is a 700R4 even asked the tranny guys when they serviced it the first time and he confirmed it.
  10. mini_mull
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    It's the same tranny, they just changed the name.
  11. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    no its not
    700R4 was changed in name in 91/92 to the 4L60, then in 93/94 it went to electronic controls, name changed to 4L60E
    Turbo 400 was hydraulic shift 3 speed, in 91, a 4L80E became avalible, it was pretty much a Electronicly shifted T400 w/the addition of OD
  12. dave_90_blazer
    Jan 1, 2004
    688
    4L60E was not in trucks till at least 92, but they are discusing the 4L80E
  13. mini_mull
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    I said these are the same. We AGREE! I know we were discussing the 4L80E before, but then tech777 mentioned he had the 700R4 not the 4L60E as quoted above. Which we both said was just a name change when they added the electronic controls. ;)
  14. globaljames
    globaljames Registered Member
    Apr 2, 2004
    52
    AZ. Scottsdale
    OK so what the diff between a 60 and a 80 ? I also want my 1/2 to be a bit stronger thanks J.
  15. mini_mull
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    4L60E=700R4 auto OD with electronic controls and a new name
    4L80E=TH400+overdrive with electronic controls
    A lot of guys hate 700R4s cause they break. However, a lot of other guys run "built" 700R4s and never break them (like the ones from bowtieoverdrives.com). A stock TH400 or 4L80E is much tougher than a stock 700R4, which is why they came standard in the 3/4tons. Both need to be kept cool in order to not bust which is why the most important tranny upgrade is a tranny cooler and maybe a gauge. (Boy I'm getting good at regurgitating all the info I've learned on CK5, thanks for schooling me guys.)
  16. globaljames
    Apr 2, 2004
    52
    AZ. Scottsdale
    Thanks... Im am running a 4L60E in a 91. Whith out a bunch of major work what favorable upgrades can be applied in steps in need be. I have a cooler (AZ) and due to my interest in a quad trailer or somthing multi purpose I dont want to be un prepared. Already looking into a 14b ff .. Thanks J.
  17. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,086
    487
    Grand Rapids area
    Everyone has missed another important difference: springs. With the long wheelbase, the 1/2-ton sub rides pretty good, but the 3/4-ton version adds 62 leafs to the pack for dump-truck ride :haha: (oh yeah, and increased load capacity).
    Some of the 3/4-tons also featured the adjustable proportioning valve in the back that adjusts rear brake pressure based on load (squat)
  18. mini_mull
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    Yeah those 8-10 leaf rear packs realy stink for ride quality. I wouldn't exactly call the ride good though in my 1/2 ton, but that might have been because the leafs were too tired. IMO, all stock rides stink. The difference between load capacities is substantial and should be noted. I was planning to do air helpers to make up the difference while towing when I had my 1/2 ton.
  19. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Also, isn't it a good possibilty that the rear axle is actually a 14b full floater, as opposed to the semi float someone mentioned?
    John
  20. mini_mull
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    I thought the 3/4ton 4x4 burbs were all SFs, and the FFs were only in the 3/4ton 2wds (maybe w/BBCs). Confirm?
