1/2 vs 3/4 ton differences?
Discussion in 'The Garage' started by firefighter184, May 4, 2005.
  1. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    I searched a while, but couldnt find a solid answer. Sooooooo....
    Exactly what, besides 8 lugs vs. 6 lugs, is the difference between 1/2 ton and 3/4 ton front 10 bolts? More splines? Thicker tubes? Are the pumpkins the same? Brakes?
    I ended up selling the 14bolts I had, to raise money for my motor fix. Now, I have a guy wanting to sell me a six lug 14b SF, with 4.10s. I have an 8 lug 10 bolt in the driveway. If I were to swap the ring/pinion and lock-rite into my 6 lug? Would it work? Why should I not do this? I have help, so labor will be next to nothing. Just looking for some ideas. Thanks gang!
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I think it would be easier to swap the 6 lug outers to the 8 lug axle, if the 8 lug axle is the one with the gears and locker you want to use.
    The axle housing and differential is the same.
  3. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Rotor's, not sure about calipers. Pumpkin, axle shafts, & tubes all the same between 1/2 & 3/4.
    John
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    You could swap everything from the knuckles out off of your 6 lugger onto the 8lugger. It would be alot easier and you wouldn't have to deal with setting up gears!
    Actually, if memory serves me correctly... The 10 bolts all used the 2nd design, big bearing, spindles. So you could just swap you rotors, hubs, and caliper brackets... THe knuckles will be the same as well as the axleshaft stubs and lockouts..
  5. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Exactly! This would be much easier than swapping gears.
  6. coptezr
    coptezr 1/2 ton status
    Jan 13, 2005
    342
    Kennewick,Washington
    hmm........
  7. firefighter184
    Apr 5, 2003
    2,763
    The Barrio
    Guess I'll be learnin me some axles tricks in a week or two...
  8. coptezr
    Jan 13, 2005
    342
    me too :p:
  9. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Just do it. All the parts should swap over between 10 bolt fronts. If they are both 10 bolt fronts the are basically identical except for the brake backing plates and hub and rotor assembly.
    The knuckles are the same, the calipers are the same, the spindles are the same, the wheel bearings are the same, the locking hubs are the same, and the axleshafts are the same as long as both axles are either 28 or 30 spline.
    If you have ever repacked your wheel bearings then you can swap 6-8 lug.
    Harley
  10. coptezr
    Jan 13, 2005
    342
    so what would be the cost to do the shafts?
  11. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am not exactly understanding your question. Can you clearify it?
    28 spline 10 bolts (1/2 ton or 3/4 ton) are the earlier versions available from about 79-88. The 30 spline 10 bolt (either) are the later versions from 88ish-91.
    As long as the axleshafts are the same spline count between his 1/2 and 3/4 ton he can swap shafts or use them as spares and also swap the locker.
    Harley
  12. WARP1
    WARP1 Registered Member
    Apr 8, 2000
    63
    Omaha, Nebraska
    The 8-lug 10b has the 12.5" rotors vs the 11" on the 1/2 10b.
    If you like your current 1/2 wheels and tires I'd say stay 6 lug. If you have been dreaming of new wheels them convert to 8-lug.
    I believe the 6 lug axles for the 14b rear are $90 each. You'd need new drum brakes also. If you want rear disks now might be a good time to do that also. It is more expensive to do rear disk on a 14bsf (maybe $400) that a 14ff (I spent $200) so you might want to consider that as well.
    The center sections and axles are the same on the 10b fronts. I am not sure about the axle tube thickness, but I believe that is the same also.
