1/2ton-3/4ton D44-10BOLT
Discussion in 'The Garage' started by CHEVY 4WD, Apr 1, 2003.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    BESIDES HUBS whats diffent between the ½ton and 3/4ton 10bolt and I want to know the same for the D44 Is it Just hubs or is it spindels or any thing else too?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    both axles, everything from the knuckles out are different from 1/2 to 3/4....everything else is the same
  3. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Exept the 10 bolt.. Some where in 30 spline and some where 28..
  4. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    So what would it take to make a 3/4 ton 6lug?
  5. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    8 to 6 lug adapters
  6. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    Ok with out spending over $200 per axle.
    Could you change the hubs and spindles?
  7. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    the only thing that is the same is the outer bearing,calipers,and the knuckle.nothing else interchanges.you have to have everything from the spindle out.so spindle,backing plate(caliper mount),hub,rotor,bearings,all have to be changed out to make it 6 lug.
  8. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    So you 100% sure I would have to change the spindles to right? /forums/images/graemlins/1zhelp.gif
  9. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    As far as spindles go
    No difference in 1/2 to 3/4 ton.
    The only differnece is 1st or 2nd design.
    1st design goes up to about '76 for D44's
    All 10B's are 2nd design.
    You then need the hub to match the spindle design.
