1/2ton to 3/4 u joint part #'s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by efilnikufecin, May 21, 2002.
  1. efilnikufecin
    efilnikufecin 1/2 ton status
    Feb 27, 2002
    168
    flint,mi
    1/2ton to 3/4 u joint part #\'s
    i'm getting ready to swap out my 1/2 ton stuff in my 91 K5 and swap in 3/4 ton.what's the part#'s for the conversion u-joint for the rear driveshaft?it will be a 10 bolt to 14bolt ff.thanks in advanced
  2. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Re: 1/2ton to 3/4 u joint part #\'s
    I bought a bastard joint from Carquest so I could use my old 1310 driveshaft as a spare in my 1350 driveline. Their PN is 3-3140. On the box it says that the supplier is Neapco and it is made is the USA. Still, the bastard joint will be the weak link in your driveline. If you cannot find the same PN I did, you can have a parts look it up in their book. It should be listed by the Spicer part numbers and is called a Spicer 1310/ 1350 conversion kit.
  3. fulltopblazer
    fulltopblazer 1/2 ton status
    Aug 1, 2001
    484
    Altus,Oklahoma 73521
    Mine was a precision 348 I believe from parts plus or napa. Pricey though
  4. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    It'll be either Napa 348 or 447
  5. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    I got mine at Napa - part # 348. They are about $30.00.
  6. efilnikufecin
    Feb 27, 2002
    168
    flint,mi
    thanks guys.
  7. coincidentally
    coincidentally Registered Member
    Apr 23, 2001
    53
    MA, USA
    did you ever find out the part number of tha thybrid u-joint? i'm currently looking for that same u-joint (same setup as you, moving from a 10-bolt to a 14-bolt FF)
