1/4 eliptic setup and 4inch rear shackle flip.
Discussion in 'OffRoad Design' started by k10clown, Dec 2, 2004.
  1. k10clown
    k10clown Registered Member
    Nov 10, 2004
    44
    Warren, Michigan
    Will the 4 inch rear shackle flip kit work with a 1/4 eliptic setup? Would this get a good setup for more travel from the rear? Hopefully this is not a stupid question.
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    From what i know about 1/4 eliptical setups. (Which is not very much) you don't even use the rear spring mount since there is no spring there.
    I am sure someone with a little more knowledge will chime in
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    you mean 3/4 elliptical and it will not. The rear spring eye mounts to a shackle which mounts to another 1/2 of a leaf spring. Ask in the garage about this setup. Only on person I know on this page has it, he finds it alright but will be replacing it. The setup has its issues in a fullsize.
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    You could use the flip with a 3/4 ellip but it would likely have to be moved on the frame to work. In general, 3/4 ellip causes problems on a fullsize because of the axle wrap tendencies and the uncontrolled droop can be a problem on a rig with a higher CG. These issues can be addressed but lowering the CG is tough without a LOT of work and typically loss of full size truck function.
