1/4 elliptical suspension
Discussion in 'The Garage' started by DesertDueler2, May 5, 2005.
  1. DesertDueler2
    DesertDueler2 1/2 ton status
    Dec 25, 2004
    132
    Chandler, AZ
    Anyone have some good pics, or a writeup of this. I want to run this in the rear of my new project.
    Dan
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Marv runs it front and rear on his buggy. There might be some shots of it running around on his webshots or other AZ guys webshots. You are aware of the fact that you need to link the rear axle and that 1/4 elliptic tends to have alot of rear steer. You probably do know, but I just want to mention them incase.
    Harley
  3. DesertDueler2
    Dec 25, 2004
    132
    Chandler, AZ
    I have seen some shots of Marvs buggy, and I saw the buggy when I was in tubing stage with the 1/4 elliptical installed. I wasnt into it then to pay much attention. I am now building my jeep that I got for free. I am taking the motor out of my blazer(Putting a new one in). Bought a th350 and a toyota t-case adapter to use in my toyota, but decided I dont like the compact truck, so I am taking the dual t-case setup and axles off of it and putting all of it into the cj5. My problem is rear d-shaft length, thats why I want to go 1/4 ellip.
    Dan
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    There are a few other routes beside 1/4 elliptic.
    Air Shocks
    Coil springs
    coilover spring
    air over hydrolic
    and others to I am sure.
    1/4 elliptic is pretty straight forward though which is nice. You just gotta learn how to drive it with the rear steer. Marv has gotten pretty good at it and can actually use it to his advantage sometimes.
    I know he is using 63" chevy spring packs cut in half for his springs. They flex like mad. Probably to much for the short wheelbase of a CJ5. I would also stretch the CJ5 wheelbase if I was you by at least 10" if not more. I would want to get it to somewhere around 95-100" and get its track a little wider for stability. Maybe full width axles or at least wider axles with rims with less backspace.
    I know that my CJ5 (narrow track with normal wheelbase) is not to great when it comes to stability.
    Harley
  5. DesertDueler2
    Dec 25, 2004
    132
    Chandler, AZ
    My plan is 102-105" wheel base. As for axles, I am going to stick with the toy axles because they have 5.29s and lockser f$r.
    Dan
  6. retroblazer
    retroblazer 1/2 ton status Premium Member
    Nov 30, 2003
    280
    148
    Gustine
  7. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    The quarter elliptical factor has NOTHING to do with rear steer. Rear steer is caused by the location/length/etc. of the links, not what is holding the truck up.
