1.5 or 1.6 rockers ?
Discussion in 'The Garage' started by y5mgisi, Jun 8, 2003.
  1. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    How can i see if i have the 1.5 or 1.6's on my truck? is it realy worth it to have the 1.6's or arethe 1.5's plenty fine. /forums/images/graemlins/confused.gif
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    is your engine stock? if so you have 1.5...a higher ratio rocker equates to more valve lift than stock rockers at a given amount of cam lift. it can be beneficial, but I wouldn't spend the money ot get higer ratio rockers unless you are doing lots of other things, like a cam, headers, intkae, etc...For example, on my 454 that I build for my K5, I have the stock ratio rockers but in a roller version...I personally feel that there is a greater benefit to going with roller rocers than a higher ratio rocker...
    Chris
  3. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    I agree with fortcollinsram. You may see a little gain by going to the 1.6 rockers a stock cam , but most aftermarket cams are designed to work the best with 1.5 rockers. You also need to consider piston-valve interference with an aftermarket cam and 1.6 rockers.
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Yep, 1.5s are stock fer small blocks...
  5. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    I went with 1.5s worked out great!
  6. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    See thats the thing is that i know the motor is modified but I dont know if theyt put diffrent rocks in when they did all the other work. (it was done in 1990). and the cam im running is about the smallest one you can get(252h comp cams) so it has veary little lift and duration. So i figured bumping up the rockers would give it more lift and duration making it seem like a bigger cam. Am I crazy or was i misinformed about the benifits of 1.6 rockers? /forums/images/graemlins/1zhelp.gif
  7. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    extra money????? what? they close the same price
    851-1001 1.5 Ratio, 3/8'' Stud (16/pkg.) $182.99
    851-1002 1.6 Ratio, 3/8'' Stud (16/pkg.) $197.99
    with some dich pistons, or ones cut to avoid interference and a high lift cam they can be very beneficial.
  8. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Do you think I have enough clearnce sence im running that small cam I think it would be OK.
  9. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    what pistons are you running? if they are inverted dish i wouldn't risk it, if flat top then you should be OK
  10. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    I have no idea. I know the comp ratio is up about .5 of what it was before motor mork .I could probly call dad and ask him he might remember.
  11. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    From the description of your motor, there is a very good chance that the 1.6 rockers will work fine. Don't expect a huge difference with the but-crack dyno though.
    Try pulling one of the old rockers off and looking it over carefully, the ratio might be stamped on it. If you don't see a ratio stamped on it, then more than likely it is a factory 1.5 . With a basic rebuild, most people don't even bother to change the rockers. I used Cam Dynamics aluminum roller rockers, made by Crane, and cheaper too. I've used two sets with no problems.
    Aftermarket rockers are more accurate than factory ones, but at this level I don't feel they are necessary.
    If you are looking for 'bang for your buck' then go with a set of headers and a free flowing exhaust. That but-crack dyno WILL notice that mod. /forums/images/graemlins/grin.gif
  12. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I would rather run flat tops and 1.5s than dished and 1.6s. Higher compression will bring better gains than that lift change in almost all conditions. Only time I would do it is if I was somehow already running like 12:1 and it would just bump me down to like 11:1. but higher compression can be higher fuel octane needs.
  13. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Well thanks for all the info guys. sounds like i'll just stick with what i got. as for the headers that will be tough because i have a PTO winch that runs off my 205 tansfer case, so the drive shaft for it is right in the way of where the headers will need to be /forums/images/graemlins/mad.gif
  14. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    shortys? won't be as big an improvement as long tubes but still better then them big heavy blocks of steel they cast in the plant
