1" add a leaf on driver's side only??????
Discussion in 'The Garage' started by bear, Dec 9, 2003.
  1. bear
    bear Registered Member
    Sep 16, 2002
    31
    Georgia
    1\" add a leaf on driver\'s side only??????
    My rig is uneven in the rear..Driver's side rear sits about an inch lower than other corners....I have 2.5" lift (blocks in rear and springs in front). Can I level out the rear with a 1" add a leaf? Anyone have similar problem? Suggestions?
  2. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    Re: 1\" add a leaf on driver\'s side only??????
    At work we had one that wouldnt sit strait so we sent it to the frame shop and it came back with a inch hunk of steel in between the front drivers coil anc the frame.
  3. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    This can be caused by several things, bad bushings, broken leaf, or bent frame. I would check the bushings and springs before I used an add-a-leaf on one side.
  4. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    766
    Granbury, TX
    My brother's C10 has same problem... the rear drivers side spring is sagging about 1.5 inches ... solution: new rear springs
  5. bear
    Sep 16, 2002
    31
    Georgia
    Cant afford new springs right now, and if it is a frame or body mount problem, the sag would still be there..........I am loooking for a cheap, easy quick fix to leveling the rear. suggestions??????
  6. chubbybob
    chubbybob 1/2 ton status
    Oct 18, 2002
    730
    I have pulled a lot of suspensions apart adding lifts for friends and have seen springs added in different packs to add ride hight its mostly been on work trucks where the original owner hauled a lot of weight in the back like tools and other things mainly on one side so the truck would sag to that side after time the springs would stay that way even with nothing in the rear. the best way to fix the problem is new bushings and springs but if you cant afford that I dont see how it could hurt to use an add leaf. I havent done it but I have seen a lot like that. /forums/images/graemlins/thinking.gif
  7. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    Go check out the springs off a truck in the wrecking yard and see what they want. Shouldn't be too bad, and it might work out for ya.
    -Andrew /forums/images/graemlins/usaflag.gif
  8. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Springs from a junk yard would cost less than a 0-rate. The other thing you have to ask is why is it sagging...I bet you have at least one broken leaf in that pack!
  9. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    3
    Houston, Texas
    I dont wanna hijack this thread, but my pass side is 3/4" lower in front and rear. I just installed my 6" all spring lift 1 month ago....wtf could this be...bad front spring pack or rear or both? /forums/images/graemlins/confused.gif
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Your springs will settle, just wait and see what happens.
