1" add a leaf
Discussion in 'OffRoad Design' started by dyeager535, Apr 19, 2001.
  1. dyeager535
    26,979
    1\" add a leaf
    Someone on the "big" board said that ORD can make these in any "reasonable" size. True?
    My truck "sags"(actually think bent frame slightly now) more on one side than the other, and I'm curious, depending on the route I decide to go, Would it be possible to purchase just 1, in case I get all new springs? Either that or its off to the frame shop... Thanks!
    Dorian
  2. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Re: 1\" add a leaf
    Just a thought, but are you sure your springs haven't sagged unequally? You can have them re-arched. If you remove and replace them the charges aren't to bad, a lot cheaper that new springs.
    Derf00
    http://www.derf00.coloradok5.com
    "Four wheel drive allows you to get stuck in a more inaccessible place."
