1" add a leafs??
Discussion in 'OffRoad Design' started by down4thakrown, Jul 20, 2004.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    1\" add a leafs??
    is there any drilling required to put them in the rear with a 14blt gm ff???
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: 1\" add a leafs??
    Not one bit. Just C-clamp your spring pack near the center pin, remove the old center pin and bolt in the 1" zero rate with a 1" longer center pin and your good to go /forums/images/graemlins/thumb.gif
  3. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    Just curios, but wouldn't it be better to clamp the spring pack about 3" to each side of the center bolt to allow for the zero rate to go on easier? I haven't done mine yet, so don't know from experience.
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Yeah, when I did mine, I actually used 2 c-clamps, one on each end of the shortest leaf /forums/images/graemlins/thumb.gif
  5. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    what about putting them in the front??
    do i have to drill??
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    The add-a-leaf zero rates come pre-drilled. But I've heard of people redrilling their spring packs to relocated their axles. I didn't, just just mounted mine in the normal spot.
  7. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    No drilling, just bolting. I don't recommend drilling the spring pack to offset axles, the closer that hole gets to the edge of the pack the worse off you are. The old hole is just going to become a stress concentration point for the leaf to break.
