1" body lift ?
Discussion in 'The Garage' started by Chrisblazzer89, Dec 1, 2006.
  1. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    How many things would I have to fix if I get a 1" body lift on my 88 BLAZER ?
    It now has 4" Rough Contry lift springs and no sway bar on 33s.
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I just had to adjust the shift linkage and trim the fan shroud.
  3. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    What exactly did you do? I want do do this in the liltlest amount of time and all the info would be great. Plz and thank you.
  4. cbbr
    Jul 17, 2004
    14,681
    Loosened the shift linkage when I started and tightened it when I finished. I used a hacksaw to cut the shroud. The whole process took around an hour.
  5. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    sorry to hi-jack, but is the 1" body lift enough to run a doubler thats been clocked up without needing to cut the floor?
  6. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Kool if i have any problems i will post them up.
    I will also Post pics before and after
  7. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    No prob HiJack away
  8. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Here's what I had to do on my 84.
    Cut the bottom fan shroud
    Adjust the steering shaft
    Add some length to the tranny linkage
    Cut or you could just take off the tailgate springs ( I took them off)
    I think that was about it...but it took a long weekend to get it done.
  9. cbbr
    Jul 17, 2004
    14,681
    Keep in mind that my truck is a rust free Suburban. I didn't have to do anything to the tailgate and all of the body bolts were very easy to get out.
