1" body lift
Discussion in 'OffRoad Design' started by JTB, Dec 20, 2000.
  1. JTB
    JTB 1/2 ton status
    Dec 5, 2000
    192
    CA
    1\" body lift
    I'm pretty sure I'm going to go with the lift. Will I need to lengthen the steering column for this short of a lift? What grade are the bolts? Thanks,
    Jeff
    Don't drive it unless it says Chevy!
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Re: 1\" body lift
    You won't need to mess with the column, that usually happens with 2" and up, so you'll be fine. The bolts are GR 5. We decided they were ok after I ripped a mount out on the frame side and the bolt held it all together. They also have a bit more "give" before they break than a Gr8.
    SW-ORD
