1 gen fender triming???
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by tom4, Jan 30, 2006.
  1. tom4
    tom4 Registered Member
    Aug 8, 2005
    86
    dallas
    I am upgrading to a 39' or 42' tire. Can Get some pictures of 1 gens with trimmed fenders. Also is there a 42' SS bogger? I can't find one.
  2. LucasJ03
    LucasJ03 1/2 ton status
    Sep 18, 2002
    289
    Ft. Fun, Colorado
  3. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
    I'm putting 39.5's on soon, I'll take pics when I do.
    Only trimming on mine is the lower rear section of the front fenders.
    Lucas, sweet K5.
  4. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
  5. RGV72BLAZER
    RGV72BLAZER 1/2 ton status
    Jan 23, 2006
    2,425
    Edinburg*San Bene*Online-The Real South Texas
    no production 42" boggers...try some TSLs or IROKs...i was planning on running 42 iroks but decided to just run 44s or 46s. good luck on the build.
  6. vtblazer
    Sep 30, 2003
    2,471
    Central VT
    Installed my 39.5's and found out I do need to trim a bit more...
    Gotta trim both the front fenders (behind the tire) and the quarters (in front of the tire)
    Plan on trimming on the line marked...until I find out different.
  7. RGV72BLAZER
    Jan 23, 2006
    2,425
    great looking Gen 1 K5
  8. tom4
    Aug 8, 2005
    86
    dallas
    I have decided to upgrade to 42' inch ss tsl. I have these in 37's and have never been disappointed. What do you think????????
    I highlighted the areas that I think I will need to trim. I will move my axles a bit to allow for more clearance.
  9. tom4
    Aug 8, 2005
    86
    dallas
    By the way VTblazer, Thats a good lookin' Blue on your blazer.
  10. vtblazer
    Sep 30, 2003
    2,471
    Central VT
    Wow, their close in color. Your gray top looks better IMO.
    I was considering 42's but chickened out...
    Cost and the amount of trimming I would need decided for me.
    The yellow areas look about right, same places I'll be cutting.
  11. RGV72BLAZER
    Jan 23, 2006
    2,425
    what about trimming on the inner rear fenders? or it wont' rub there?
  12. vtblazer
    Sep 30, 2003
    2,471
    Central VT
    Won't on mine, the rear axle has been moved forward 1.5 inches.
    Kinda looks strange sitting forward like that but seems to work.
  13. RGV72BLAZER
    Jan 23, 2006
    2,425
    that does look kinda strange :ignore: :D
  14. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Have you got a larger photo?
    My guess is that the forward edge of the front fender won't need to completely disappear like you have shown.
    Also, the leading edge on the rear may not need much trimming once you move the axle back...I'd consider going more than 1" though....maybe 1.5 - 2" unless you've already moved it once. It takes at least 1.5" to center the wheel on a 1st Gen.
    Remember, with a leafspring/shackle setup the wheel travels BACK in the wheelwell as it travels UP....on mine, I only really needed to heavily trim the trailing edges (admittedly, only for 38's though)
    :usaflag:
  15. tom4
    Aug 8, 2005
    86
    dallas
    I'm sure with the width tire I’m going with the inside fender will rub. I have a solution to this however. (its long so I’m not going to type it. I'm thinking the best thing to do will be to put the tires on my truck. Then find out what needs to be trimmed. I'm not even sure that I’m going to move my axles
  16. tom4
    Aug 8, 2005
    86
    dallas
    Screw it! i'm just gunna make sure they fit! what do you think [​IMG]
  17. vtblazer
    Sep 30, 2003
    2,471
    Central VT
    :eek1: Bye - bye inners...
    Put on the tires your going to run, flex it out and see where it needs to be "fit"
  18. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    i still think you need to trim into part of the removable top as well. just to be sure :haha:
  19. Ryan B.
    Jul 18, 2001
    5,693
    CA
    I used a forklift and a sawzall to clearance my fenders for 38's. Left under 1/2" of clearance...
    Then i went wheeling and somehow flexed it out harder! :rolleyes: I guess i didn't clearance em enough! I'd say leave at least an extra inch of clearance when flexed on the rear part of the fender for both the front and back if you don't want em to get munched by your tires.
  20. RGV72BLAZER
    Jan 23, 2006
    2,425
    :haha: that's too funny. but it hurts to think that there are Gen1 K5s out there with that much fender trimming.
