1 inch add a leaves
Discussion in 'OffRoad Design' started by eastk5, Jul 24, 2001.
  1. eastk5
    eastk5 Registered Member
    Jul 24, 2001
    50
    Norfolk Virginia
    I recently installed rancho 2.5 inch springs front and rear , with ord shackles in the front. the rear end sag is irritating at best . Will your 1 inch add a laves work with the rancho springs?
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Those 1" add-a-leaves will work with ANY springs.
    <font color=blue>Daddy told me while learning to pee......"if you shake it more than twice, then you are playing with it!!!"</font color=blue>
  3. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Could you please post some information on the rear springs ?
    If you could read the p/n thats usually spray painted white that would also help.
    Thanks alot
  4. eastk5
    Jul 24, 2001
    50
    Norfolk Virginia
    p/n on rear springs are rs 86209
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    No problems with the rancho springs, they'll bolt right on to about any spring that's 2.5" wide.
    Making the world better, one truck at a time.
    SW-ORD
