1" Lift
Discussion in 'The Garage' started by CooknwithGas, Jun 2, 2002.
  1. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    1\" Lift
    Does anyone know where I can get 1" blocks for the rear springs. I want to level out my truck and it is a little too high in the rear with the 2-1/2" lift blocks.
    I looked through the links page, but couldn't find anything obvious for this sort of thing.
    Thanks in advance for any help.
  2. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    Re: 1\" Lift
    hit the CK% membership link then go down to ORD. they have 1" addaleaves. It looks just like a block but bolts to the spring pack
  3. CooknwithGas
    Nov 27, 2001
    332
    Istanbul, Turkey
    Re: 1\" Lift
    I must be blind - I didn't see it at www.offroaddesign.com.
    Any idea on the cost? Thanks for the tip.
  4. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    Re: 1\" Lift
    Well I know ORD did sell a add-a-leaf that was something like a 1in block But I could not find it sorry. What you could do is go to the ORD forum and ask those guys.
    Eric
  5. sapper
    Jul 11, 2001
    3,052
    NoVa
    Re: 1\" Lift
    Look Here
    <a target="_blank" href=http://offroaddesign.com/catalog/Zero%20Rates.htm>offroaddesign.com/catalog/Zero%20Rates.htm</a>
  6. Highlander
    Nov 25, 2000
    1,204
    Lakewood Colo
    Re: 1\" Lift
    Hell, I missed them as well.
    Eric
  7. CooknwithGas
    Nov 27, 2001
    332
    Istanbul, Turkey
    Re: 1\" Lift
    Sapper: You Da Man! Thanks. That is exactly what I need. Gonna order them today.
    Thanks again,
    Scott.
  8. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Re: 1\" Lift
    could you just take a old spring and cut it down?
  9. sapper
    Jul 11, 2001
    3,052
    NoVa
    Re: 1\" Lift
    you could but you would just get 3/4" of lift and not be able to move the axles if you wanted to.
  10. CooknwithGas
    Nov 27, 2001
    332
    Istanbul, Turkey
    Re: 1\" Lift
    For $40 I'm getting both blocks and a the long bolts to attach the blocks. It also will give me the option to move the axle back or forward (doubt that will happen). Thanks again for the help. I'll install it this weekend and let you know how it comes out.
  11. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Re: 1\" Lift
    I ordered my zero rates last week cause I need to move my rear axle back 1" or 1.5"s. I don't need the lift so I may take out the thick over load in this pack and put a thinner one in it's place.
  12. CooknwithGas
    Nov 27, 2001
    332
    Istanbul, Turkey
    Re: 1\" Lift
    I'd like to see pictures of before and after the axle move.
  13. CooknwithGas
    Nov 27, 2001
    332
    Istanbul, Turkey
    Re: 1\" Lift
    Bruce:
    Did you install the spacers yet? I got mine in and will be installing them this weekend. I'll let you know how it went.
  14. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    Re: 1\" Lift
    Same here.
  15. CooknwithGas
    Nov 27, 2001
    332
    Istanbul, Turkey
    Re: 1\" Lift
    OK, I got it installed on both sides. Always expect the unexpected. Now I need new U-bolts and the front end was too high after installing the 1" spacer on the rear (I had 2-1/2" blocks with brand new rear springs). So I took out a leaf from my front springs (2-1/2" lift springs) and that about leveled her out. I have 1/2" higher in the rear than in the front, and it looks better now. Handling seems fine and I like the fact that there are no blocks on the rear.
    Overall it was not a big deal to install the spacers, but the U-bolts were a surprise. I thought I would have enough threads, but it didn't happen. Taking a leaf out of a spring was no big problem either.
    Good luck with yours.
