1 man brake bleeders
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 87superblaze, Feb 21, 2002.
  1. 87superblaze
    87superblaze 1/2 ton status
    Mar 12, 2001
    104
    Upper Michigan
    It may be old news but I found some bleeder screws at the part store that bleed themselves! I guess you turn them 2-3 turns out and pump your brakes and Boom, your done.
    If I would have know these existed before I changed Axles like 300 times, it would have made my life very easy.
    Just a tid bit of information. Hopefully this will help out someone else that doesn't know about these.
    My Truck <a target="_blank" href=http://www.community.webshots.com/user/nicksm79>http://www.community.webshots.com/user/nicksm79</a>
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I have good luck just gravity bleeding
    formerly 77chev
    still a jerk though
  3. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Would you really trust them? I'm leary of one man bleeding kits/things.
    Mudstud
    <a target="_blank" href=http://communities.msn.com/OffroadK5s/6superliftand33s.msnw>http://communities.msn.com/OffroadK5s/6superliftand33s.msnw</a>
    76K5 6" with 33s, sb400/350/203parttime/3.73-D44/GM12bolt
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,081
    486
    Grand Rapids area
    I've seen kits in 4x4 mags that you hook to the bleeder and push fluid backwards from the caliper up to the master cylinder. They claim that this is more effective since air tends to rise anyway. I have been thinking of trying one.
    <font color=green>Top signs you don't have a real 4x4:
    4) Twin Traction Beam
    3) Made by D.C.
    2) 5 lug nuts
    1) Unibody</font color=green>
  5. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    I have bled backward from the caliper. Took an old oil can that you use to oil small thing that has a little level pump on it. Just hooked a rubber hose from it then put hose over the bleeder screw. Have brake fluid ion the canister tehn looses bleeder and pump it till no more air is coming from the master cylender. Works pretty good. One person too!
    '86 GMC shortbox 3/4 ton
    <a target="_blank" href=http://www.picturetrail.com/mnorby>www.picturetrail.com/mnorby</a>
  6. Parf
    Parf Registered Member
    Nov 16, 2001
    81
    Golden, Colorado
    Man, I LOVE SPEED BLEEDERS!
    Crack one open, and pump the brakes until nice clean fluid comes out, tighten and move on to the next. So much easier than &lt;Pump&gt; "Okay???" ...."Okay!" &lt;Pump&gt; "Okay???" ..."Okay!"
    All my vehicles will have them soon. I got mine from Russel (Now Edelbrock). It's just too easy.
    <font color=blue>Parf</font color=blue>
    1984 K5 Jimmy 4x4 Sierra Classic
    6.2L diesel, 700R4
