1 military "Hutchinson" 20" beadlock insert
Discussion in 'Tires | Wheels' started by DPI, Mar 15, 2006.
  1. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    This came out of a 5 ton wheel that I had purchased for the tire. No need for the instert. This is the metal instert that has the rubber molding around both sides and is the split design, using two bolts that connects the split. It is a piece of cake to install vs. the solid PVC or Rubber inserts.
    Only one available...
