1 more question 2nite
Discussion in 'The Garage' started by blazin_blazer, Feb 7, 2007.
  1. blazin_blazer
    blazin_blazer 1/2 ton status
    Aug 2, 2005
    4,043
    central arkansas
    a np205 from behind a th350.. does it have the same input shaft as a np205 from behind a th400. if not do they make an adaptor for the different splines? or would it be better to swap input shafts also ...i'm converting a 2wd tranny for 4wd duty.:bow:
  2. blazin_blazer
    Aug 2, 2005
    4,043
    central arkansas
    3 easy ?s
  3. goldwing2000
    goldwing2000 Guest
    No.
    No.
    No.
    The t-cases are completely different. The TH400-style case has a larger bearing, a female input and a slightly different housing. The TH350-style case can be modified but it requires machining. Definitely not a bolt-on application.
    TH350, TH700R4 and SM465 share the same style input but with different shafts. TH400 is the bastard child in design but is the strongest.
  4. k30bb468
    k30bb468 1/2 ton status Premium Member
    Oct 2, 2004
    955
    NW Pennsylvania
    There is a small bearing T400 NP205 .
    So you just need the correct NP205 input for your transfercase & it will work
    Here's a couple pics of the large bearing NP205 for comparison
  5. goldwing2000
    goldwing2000 Guest
    Neither of us can view those pictures.
    I can't even begin to imagine how rare a small-bearing 205 must be, though.
  6. k30bb468
    Oct 2, 2004
    955
    NW Pennsylvania
    Not rare at all , any T400/NP205 85 & earlier would have the small bearing
    32 spline input & figure 8 adapter.
    (How do I post pics so you can see them ??????)
  7. goldwing2000
    goldwing2000 Guest
    I just don't see how you can have a small bearing with an input shaft that's so much bigger. Everything I've read says that the female input shafts all use the large-size bearing. Here'a an example from ORD's web site:
    http://www.offroaddesign.com/NP205tech.htm
    Doesn't say anything about small-size bearings on the female inputs. :thinking:
    Anyway, to post pics that non-members can see, they have to be hosted on an external web site and img linked on your post.
  8. k30bb468
    Oct 2, 2004
    955
    NW Pennsylvania
    PM me your email & I'll send ya the pics
  9. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i believe your pictures only show the difference between a long & short 32 spline input. both the 32's are large bearing cases.
  10. goldwing2000
    goldwing2000 Guest
    can't pm, either. :D
    goldwing2000@comcast.net
