1 or 2 pumps for Hydro Assist and Hydro Boost??
Discussion in 'The Garage' started by txfireman110, Jan 25, 2006.
  1. txfireman110
    txfireman110 1/2 ton status
    Nov 1, 2003
    294
    San Angelo, TX
    I'm running hydro boost brakes and am about to add hydro assist as well. Will one pump run both systems efficiently or should I use two pumps? If I need two, what is the best and easiest way to set it up???
    1 ton K5 with a 454
    Thanks:bow:
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    I personally havent done hydro assist, but I would think one pump would be fine as lone as you dont mash the brakes and turn it back and forth as fast as you can. I would add a cooler and a reservoir though.
