1 out of 8 plugs is fouled out??? engine problem.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by foxman, Mar 12, 2002.
  1. foxman
    foxman 1/2 ton status
    Oct 22, 2001
    251
    Detroit MI
    O.K. thought it was a rod knock, but after i replaced the fouled out Delco plug with a Champion Platinum, the truck runs nice! I've put about 20 bhighway miles on it today and it seems fine. It looks wet and black (the plug that is) when I pull it, but like I said, it runs fine for now, no knocking or anything. I'm guessing that somewhere down the road, I'll be right where I was before when it is comletely fouled out(knocking and running rough). I did a complete comperssion test and every thing was normal. I tried an old plug wire that looked fine and ran it for about 5 minutes on that plug, but it was still black and wet. So if the wire is good, the plug is good, and the compression is good, What else could it be? I'm trying to get it ready for a 500 mile trip to Canada this week.. Please help!!! Thanks.
  2. Storm Trooper
    Nov 24, 2000
    4,640
    Do the other basics. Cap, rotor, timing.
    Might be time to take a good look at the carb. and choke.(sorry, I forgot to check what you have in your truck).
  3. sagechicken
    sagechicken Registered Member
    Feb 19, 2002
    71
    Wyoming
    I recently had a similiar problem. The secondary's on my Q-jet were sticking open just a little allow to much fuel down the intake. For some reason it only fouled a couple plugs.
  4. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    If your carb is dripping gas into the intake for any reason, it will often foul one or two plugs. Most common reason is a Q-Jet that is leaking from the plugs in the bottom of the fuel bowls. What happens is the fuel just drips into the intake, and runs down into the cylinders that are the path of least resistance. This is because the fuel is not atomized, it is just dripping straight down.
