1 piece or 2 piece rear main seal
Discussion in 'The Garage' started by flamin_browneye, Jun 25, 2005.
  1. flamin_browneye
    flamin_browneye Registered Member
    Dec 19, 2004
    13
    Boise, ID
    I'm getting ready to order a new engine and i needed to find out which rear main seal my truck has. It's a 88 GMC Jimmy W/ 5.7L and 700R4
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Should be a one piece. Best way to tell is by the casting number. Or you can drop the oil pan and look for the goofy adapter found on the early blocks with the one piece rear seal
  3. flamin_browneye
    Dec 19, 2004
    13
    Boise, ID
    you can just buy a different oil pan to make it work right, cause my new engine has a 2 piece and the old one might have a 1 piece
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Yours will be a 1 piece if it's original, but yes you would need a different oil pan AND also a new flexplate as the bolt pattern is different and the 1 piece seal engines are externally balanced on the rear side.
  5. flamin_browneye
    Dec 19, 2004
    13
    Boise, ID
    how much do flexplates run?
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    They usually cost around $40.00 or so.
