1 piece rear main block... a few questions
Discussion in 'The Garage' started by Calclips, May 20, 2003.
  1. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    I've got a block with a 1 piece rear main on it... its a complete rotating assembly that needs rebuilding, the only problem it had was burning oil... and its never been rebuilt before. What I want to know is.... can I make this a 383 as cheap as a 2 piece block, or would it be more to my benefit to dig up an older block?
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    check SCAT or a few other for pricing on the 1 piece seal stroker cranks
    Powerhouse has them cheap.
    'as cheap' I doubt it
  3. dyeager535
    26,982
    191
    Up to you if the added cost of the crank is worth it.
    Does the block already have the roller cam/lifters, or would you have to dig some up to add them? Thats a big benefit for a lot of people, plus less likelihood of rear main leaks, along with centerbolt valve covers, and so on.
