1 Piece Rear Seal...Which way is better???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RedDwarf, Jul 7, 2002.
  1. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Ok, we're all familiar with how a one piece seal is changed...but which is better, to change it with the appliance ON or OFF the block?
    Is it worth it to remove the appliance, or can you save a little time to do it on the engine?
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    They can be quickly and easily changed on the truck with the correct tool.
  3. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    I've seen the gasket on the seal adapter leak where it seals to the engine block, when I was that close I would change the seal and the gasket to prevent having to come back and change the gasket later.
  4. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I took the adapter off the block so I could put a new felt gasket behind the adapter...It was easy enough...
    Chris
