1 piece rotor/hub or two piece???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kau, Jul 20, 2002.
  1. kau
    kau Registered Member
    Jun 10, 2002
    8
    I got a hub to hub D44 I am rebuilding.
    I went to Autozone and got rotors for 30 dollars each.
    However, not thinking they did not include hubs (this is my first axle project)
    So I go back down and inner hubs are 70 dollars.
    Or I can get rotors w/ hubs for 170 each.
    So what is the difference? How come I can get the rotor/hub seperate for 100 each compared to the 170 for them together?
    Also I bought Milemarker locking hubs so will they fit the two piece?
    Thanks!!
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Why do you need new hubs? You should just be able to press out the old wheel studs and swap the rotor and then reinstall the wheel studs...I don't see why a new hub is needed unless your is cracked...If the bearings and seal are shot, just replace those...if the hub body is solid, no need in spending the $$$ to replace it...
    Chris
  3. kau
    Jun 10, 2002
    8
    I don't have inner hubs as my D44 I got was knuckle to knuckle, it was free so I have to buy all new outers.
  4. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Do you have the spindles on the axle? If not I have the spindles, hubs, and locking hubs for the 1st design D44... $100 plus shipping for all of it...That'll get you rolling...oh, but it is 8-lug (3/4 ton D44) Let me know...Other wise I would get the combo (hub/rotor) and save some $$$
    Chris
