1 TOM AXLES
Discussion in 'The Garage' started by Z3PR, Mar 30, 2002.
  1. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    BEING NEW TO WHEELING, I ASKED WHERE TO START ON MODS. MOST EVERYONE SAID AXLES. MY LOCAL SALVAGE YARD HAS A 1 TON 14BOLT FULL FLOATING, AND A DANA 44 WITH 4:10 GEARS. THEY WANT $800.00 IS THAT A FAIR PRICE ?????? IF NOT, WHAT WOULD BE A FAR PRICE ????? SORRY ABOUT THE CAPS, CAPS LOCK NOT WORKING, CAN'T SHUT THEM DOWN.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    You can find them cheaper. I got my 14bff for $200, and you can find D44's for $250 and up. 4.10 is a good ratio, but $800 is a little steap unless they are in really good shape. Also a D44 isn't a 1 ton front end, its the 3/4 ton. A D60 is the 1 ton. They usually start at $1000 each though. A D44 axle can handle alot of good wheeling, and can be made to handle tires up to about 38". You should already have a D44 in the front of your truck, and you can convert that to the 8 lug bolt pattern to match a 14bff alot cheaper then buying a new one. I am currently converting my 1/2 ton front end to 8 lug, and it will only cost me around $200-250 with all new wheel bearings and all parts needed for the swap. So you might consider just buying the 14bff and converting to 8 lug until you can get the money for a D60, or if you don't plan on running tires over 35-36" not switch at all.
  3. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    Keep an eye on the local want ads. With some luck you might be able to find a complete 3/4 ton rolling chassis/body for under $800. You can take the parts you want, and salvage the rest. Or, you could transfer your old parts over, and sell the roller for about the same money that you paid for it.
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Look and ask around locally if you can.
    I have found them from farmers and some oil well businesses before.
    The cheapest I ever paid for a matching pair D60 and 14FF was $250, for the pair!! /forums/images/icons/cool.gif
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Where is one of those smiley faces flipping the bird when you need one. J/K /forums/images/icons/smile.gif
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Over on POR. /forums/images/icons/laugh.gif
