1 ton & 1/2 ton shackle flips
Discussion in 'The Garage' started by txfiremank5, May 31, 2005.
  1. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I'm going to run my 14BFF that is out of a V3500. I also plan to swap the rear springs to 56" packs. So, seeing as how ORD has flips for 1/2 tons & 1 tons, would I still use a 1/2 ton flip .. or do I need a 1 ton?
    :confused:
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    If the axle is going under a 1/2 or 3/4 ton then you need the 1/2 shackle flip. The 1 ton has a different spring spacing and you would have to also change your front spring hanger to a 1 ton hanger if you were to use those.
  3. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Ah.. yess..
    My perches are relocated, so yeah, I guess I would need the 1/2 ton. I just didn't know what the difference in the 2 was, and didn't even think about the perch width diff.
    :blush:
