1 ton 80ish Ford Dually axles on K5 Blazer?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TheColonel, Feb 12, 2006.
  1. TheColonel
    TheColonel Registered Member
    Jan 22, 2006
    17
    SC
    Will the front and rear 1980ish 1 ton ford dually fit under an 88 K5 Blazer? I want to upgrade from my 1/2 ton to stronger axles and I can buy this whole truck for 800. SHould I?
  2. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    In short no.
    The mid 80's ford front axle spring perches are too wide, by about 4". Plus the dif. housing is a drivers side drop on the fords, passenger on chevys.
    The rear is possible but again the spring perches will need to be moved and the hubs will make your tires stick out of the fender wells. Unless it's a c&c and then I'm not sure what that would do..
    It sounds like a fair price for the truck, you might be able part it or trade with someone for a chevy d60 tho.
  3. TheColonel
    Jan 22, 2006
    17
    SC
    Oh Well, Maybe I will still buy it and see if I can trade it like you said. :)
    Thanks for the info!
