1 Ton Axle swap
Discussion in 'The Garage' started by mil_act02, Apr 19, 2005.
  1. mil_act02
    mil_act02 Registered Member
    Jan 19, 2005
    32
    Caldwell,TX
    I just bought a D60 and 14FF for my Jimmy. Need to know what to do about driveshafts. Can I use the stock driveshafts? Do they have to be shortened? What else would be involved to make them work? Should I just wait until I can afford some custom driveshafts?
  2. aduff85k5
    aduff85k5 Registered Member
    Dec 31, 2004
    91
    florida panhandle
    i put the 14 bolt ff in the rear and i think the drive shaft needs to be lengthened. i did put a lift on it. have you done a search yet
  3. Zeitler
    Zeitler Registered Member
    Feb 22, 2005
    99
    Sweden (Northen Europe)
    somone said that it's better to have a lift because the yoke on the 14bff is longer than the old 10bolt , i dunno ...i measured and they seems to be the same length :what:
    havent checked the D60 yet
  4. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I put my 14BFF in along with 5 inches of lift. The stock driveshaft works fine, just needed a conversion u-joint from napa.
  5. sweetk30
    Nov 1, 2004
    25,544
    539
    horseheads , ny 14845
    if you measure from the frt cover back to the tip of the yoke it will be a bigger distance to them on the 1 ton axles. and a small lift will be better and help alot . and like above a trick joint at the rear only for the drive shafts to bolt up. good luck.
  6. mil_act02
    Jan 19, 2005
    32
    Caldwell,TX
    Axle help
    I have a 6" lift already so I might just need the special u-joints. :)
  7. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    On my 71, the front bolted in, the rear was another story. Then again, the truck came with a 4 inch lift, so I have no idea if the shafts were stock or not.
  8. mil_act02
    Jan 19, 2005
    32
    Caldwell,TX
    axle swap
    Can you use that special u-joint for the front? Also what did it take to install the rear?
  9. sweetk30
    Nov 1, 2004
    25,544
    539
    all frt joints should be 1310 at yoke unles some one has changed things.
  10. mil_act02
    Jan 19, 2005
    32
    Caldwell,TX
    Thanks for the help.
  11. Ryan B.
    Jul 18, 2001
    5,693
    CA
    i went through a headache.
    i was 1/2 ton and put on my suspension lift. then had my driveshafts built.
    then i went 1 ton. I'll bet my 1410 rear yoke and 1350 front yoke have something to do with my issues.. my rear came up too long and i needed to use my 1" offset holes in my spring perches to make my driveshaft work. for the front, it was too long as well. i had to shorten it. yep after i legthened it a few years before for the lift. I'll bet the stock driveshaft woulda been perfect. :crazy:
