1 Ton Axles for sale
Discussion in 'Mid-Atlantic Region' started by wayne, May 24, 2003.
  1. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    If anybody need a set of ton axles let me know. I might even put mine up for sale. BTW I know this is not the for sale board but I just thought the east coast guys would like a heads up.
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    whaddya got?
  3. LAXandBLAZERS
    LAXandBLAZERS 1/2 ton status
    Jun 2, 2002
    100
    Durham North Carolina
    what do u have (gears and stuff) and how much would those be?
  4. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    I'm not Wayne, but I'm pretty sure he has D60s and 14 bolts military ones with 4.56s. I also wanted to say these are great axles. I have one of the front 60s under my truck and one of my friends has one of the 14 bolts. They are very nice axles and well worth the money.
  5. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    D60 open with 4:56's and 14ff with Detroit for $1500. My personal axles are a D60 with a Trac Lok, 4:56's, 14ff Detroit, 4:56's. Complete minus U bolts and I also have the 3/4 ton plates for the rear, and the rear is set up for a K5. Shock mounts and spring pads already relocated. $1600.00 Must pick up. I have no way to ship them at this time.
  6. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Also members here that I have sold axles to:
    Dawson444
    Yunit
    Derf00 (3 sets)
    General
    Yield2me
    Josh (can't remember his user name)
    TorkSdr
    Plus a few others.
  7. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    The axles are so so /forums/images/graemlins/smirk.gif, I hated the fact that the gears looked like new /forums/images/graemlins/mad.gif and that I had to paint them /forums/images/graemlins/mad.gif, but besides that they were great. /forums/images/graemlins/thumb.gif
  8. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    I purchased three sets of these axles from Wayne. If you are looking for a set of quality axles that you won't require rebuilding once you get them, talk to Wayne.
    As Yunit also stated, the gears looked unused. On the set I personally kept, I replaced the calipers(personal choice) and turned the rotors on the 60, on the 14B I pulled the drums to have them turned, but instead found a brand new set of brake shoes, and drums that had been turned when the shoes were installed. Aside from gear lube, and my labor to clean and paint, I invested around $100.00 over the purchase price to bolt the axles in place, and that was almost two years ago. /forums/images/graemlins/thumb.gif
  9. tj_k5
    tj_k5 Registered Member
    May 31, 2003
    52
    South Jersey
    I guess this is a good place to lay down my first post on this site. I'd be interested in a set of these axles depending on how easy they would be to bolt up to my '91 K5. I actually sent you a PM before even reading this post about your personal axels. From just reading around the site it's my understanding they pretty much bolt right up. I'm not afraid of doing a little fabrication if I had to though. I already have an '89 F-150 with a '79 F-150 running gear (NP205, D44. Ford 9", ect.) rolling on 44's. Just trying to avoid all the extra work I can. My first order of business with my K5 is to go with the 1 tons with more lift to fit my 38's. Then I'm hoping to stuff a TH400/NP205 combo to go bulletproof. I'm sure there are plenty of folks who have done this on the site but can anybody tell me how much is actually involved? Thanks guys.
  10. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    It is a very easy swap. The front will be a bolt in deal and the rear if using a 1 ton axle will require the spring pads and shock mounts moved. A conversion u joint on the 14ff to run your stock driveshaft. Napa part #447. Otherwise everything just bolts in including the brakes if you are running 10 bolts. The Dana 44 used a different line end on the caliper then a 10 bolt or D60.
  11. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    how much for just a d60 front?
  12. tj_k5
    May 31, 2003
    52
    South Jersey
    Well, I just picked my set up yesterday and I'm very impressed with these things. We pulled the cover off them and these gears really do look new. Well worth the money!! Also, Waynes freind said he had plenty of these around so I would definatly recommend getting in touch with Wayne to talk to this guy. Can't wait to get these bad boys in!
